show iparp security
show iparp security [ {vlan} vlan_name | vlan vlan_list]
Description
Displays the IP ARP security violation information for one or all VLANs.
Syntax Description
vlan_name Specifies a single VLAN for which to display security violation information.
vlan_list Specifies a VLAN list of IDs to display security violation information.
Default
Shows security violation information for all VLANs except Mgmt.
Usage Guidelines
None.
The following example displays IP ARP security violation information for all VLANs:
Switch.4 # show iparp security
Most Recent Violation
Vlan               Security   Violations  Type   IP address        MAC          Port
Default            ----
test               ----
Security Setting: (G) Gratuitous ARP Protection
Violation Type  : (g) Gratuitous ARP Violation
The following example displays IP ARP security violation information for VLAN Default:
Switch.5 # show iparp security "Default"
Default            ----
The vr option was added in ExtremeXOS 11.0.
The vlan_list variable was added in ExtremeXOS 16.1.
Platform Availability
